CFM Configuration Using EDM
This section provides procedures to configure Connectivity Fault Management (CFM) using Enterprise Device Manager (EDM).
When you enable CFM in an SPBM network, as a best practice, enable CFM on the Backbone Edge Bridges (BEB) and on all Backbone Core Bridges (BCB). If you do not enable CFM on a particular node, you cannot obtain CFM debug information from that node.
